跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1625 个问题 查看全部
RAM Upgrade 2133 MHz now having problems
Hi,
I have a MacBook Pro (13-inch, Mid 2012)
I had upgraded the RAM modules of my MacBook Pro to 2133 MHz Using Kingston's HyperX Impact RAM, I was using these in my system for more then 2 years, a few days back, I had some GPU issues so I removed my HyperX RAM modules and Reinstalled the original Apple RAM and gave it to Apple to repair.
Apple has now replaced the Logic Board, I then put back the HyperX RAM back in my system and it only shows me a solid power light when I turn on my Mac. It doesn't boot up or make any chime noise or anything, I don't know why this is happening,
The HyperX RAM were working fine for so long but after the logic board change out there giving me issues. I even tried my RAM modules in on someone else computer and the RAM works just fine. It's just not working in my computer!
What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Is this the RAM you used? Kingston HyperX Impact RAM
Here's Apples RAM guide: MacBook Pro: How to remove or install memory
完成的
Same goes to mine... GPU glitches after few minutes, put back the 1600 MHz RAM its works fine. I used to put in 1866 MHz with no problem, no more...
完成的
添加一条评论
2个答案
已选择的解决方案
@mohur - When you start using RAM that is beyond the specs of what the system was designed to support you can get into some odd behaviors. Just because a company pushes a product as being better it may not be! Let me explain...
Think of it this way a given road has a speed limit of 35 MPH and lets say all of the cars that are on that road are at this exact speed. So having a car, bus, or truck makes no difference! As all of them run at this set speed. Now lets throw in a race car into the mix most can barely go 35 MPH as its just too slow! It spits and sputters as it tries to run at this slower speed. But on the open racetrack it can zoom!
RAM modules are very similar! The speed limit of the bus is set, you can't run faster than the bus (road). Yes, you can put in faster RAM. Doing it with the expectation you are going to get more or better performance is not really realistic.
OK lets dig deeper here by looking at the RAM's CAS speed of your RAM
What this system needs and your RAM:
Now look at your modules timing:
DDR3-1600 CL9-9-10 @1.35V or 1.5V
So depending on the given system's hardware you may encounter a problem as the range of the faster RAM is not as wide as the slower RAM. Your original systems logic board PCH may have had just enough range to support the faster RAM module unlike your current board. It's also likely Apple altered the timing a bit as that might have been one of the alterations needed to resolve the GPU problem it was facing.
References:
这个答案有帮助吗?
得分 2
8条评论:
Hi Dan is it possible to alter the Timing again.
完成的
Sadly, I don't see that as a solution here. You would be giving up the graphics for the RAM. Best to sell the RAM and get the correct speed for the system.
完成的
I agree with Dan.
完成的
Hi Dan can i upgrade to DDR3L 1866MHz Hyperx , I'm currently using 1600 8Gb normal Kingston Ram, which i find really slow even for normal use open or shutting app and all , Compared to the 2133mhz
完成的
Sadly, I think what you are seeing is mostly in your head ;-}
Give the vid a watch & read the second article:
- High Speed RAM - Is it Worth it? DDR3 1333MHz vs 2400MHz Test - Linus techtips
- Does RAM Speed Matter? DDR3-1600 VS. 1866, 2133, AND 2400 in Games
Both of these show there is no real improvement in using faster RAM in a desktop class system.
I would focus my efforts on the amount of RAM as that has a bigger bearing than the speed of the RAM. To put this into perspective a lean system (i.e.4 GB) will need to use the Drive for Virtual RAM which would be very slow Vs maximizing the RAM for the given use (i.e.16 GB).
完成的
显示更多的3条评论
添加一条评论
最有帮助的答案
In electronics, or at least Macs, processor and speeds vary in the same model. They are based on minimums. But there are variants. Some run faster than rated and some run at the posted speed.
The recommended RAM for your machine is DDR3L at 1600 MHZ. You are really trying to push that. Also slots vary. At this point I would try just one stick at a time and try it in both slots.
You may have to go back to the recommended sticks.
Can you tell us why you are pushing your machine so hard and give a link as to where it's listed that this RAM will work in your machine so we can study it a bit.
这个答案有帮助吗?
得分 3
5条评论:
Hi , i used to Use 2133 Mhz Ram on my Laptop for 2 years , now recently i had a GPU issue , so apple changed the logic Board, After Changing the Logic Board the when I install the Sticks on the New Logic Board, Only the Power Light turns on on the mac , nothing else. i don't understand why, it used to work before.
完成的
2133 MHz on a DDR3L stick!! That's DDR4 speed! Too much, I agree with @mayer.
完成的
No Its DDR3 HyperX Rams.
完成的
ya But the question is that it used to work Before On my mac I Used it For more then 2 Years without any issue. Recently i had a GPU Issue so apple changed my logic board , after the new logic board the Ram Sticks aren't working.
完成的
The fact it's only DDR3 is amazing. I have never seen clocks like that out of DDR3.
完成的
添加一条评论
添加你的答案
Mohur 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 31
总计 2,036
