跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
192 个问题 查看全部
2ds blue led turns on 1 second then turns off, console doesn't start
i press power, and the blue led turns on 1 second, then goes off, and the console doesn't start, help please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
4个答案
最有帮助的答案
Remove the SD and reformat it to FAT32 that'll fix the issue.
这个答案有帮助吗?
得分 1
添加一条评论
You'll need the boot.firm file on the root of the sd card. Specifically this boot.firm, since the latest boot.firm won't work with your softmod.
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much James!, i bought an old 2ds for less than $20 as junk. It has no scratches at all, and now after less than 1 hour of searching i read your comment and voilá! it is working!
完成的
添加一条评论
did you softmod the 2ds recently?
这个答案有帮助吗?
得分 0
2条评论:
is there a way to fix it
完成的
i tried to get freeshop for my son and then this happened
完成的
添加一条评论
It is probably the battery. Mat need to clean it or change it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rui 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 55
总计 3,807
