跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
Water damage - how to diagnose specific problem?
I was given an iphone5s that had dropped into some water. The person said they did not wait for it to dry completely before they attempted to turn it on. The phone does not work and I guess they knew that I like to try and fix things so they gave it to me.
When it is plugged in it will give 2 short vibrations and then sit for a little less than a minute and then give 2 vibrations again. Also, it gives the typical (light-gong) sound of being plugged into a power source after the 2 vibrations.
How do I go about repairing this device? What should I be considering to replace? Screen? Mother board? Power connector? How can I diagnose specific problem hardware issues? (With multimeter?)
In other words, to what extent does water damage the hardware of the iphone?
Thank you very much in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You're going to want to start with an ultrasonic cleaner, or at least a deep clean with isopropyl alcohol (91% if possible). Don't use a jewelry cleaner but instead a true ultrasonic if you have one.
Strongly recommend you desolder the emi shields on the motherboard itself to give it a quality cleaning.
Basically what you're looking for , first at least, is to remove any and all corrosion buildup on the board. When water or liquid sits it leaves minerals and deposits on the board. These deposits (corrosion) can add extra pathways for current to flow through including directly to ground...which is not where you want most components to go.
I would first do a cleaning then let it get an air dry for about 30 min to 1 hour and inspect the board. Look for physical damage such as damaged pins on connectors. If you get a schematic online you can also test main lines for shorts using continuity mode on a digital multimeter.
Also, unless you're doing this as a pure hobby I strongly advise against putting a lot of time into it for any reason other than data recovery.
这个答案有帮助吗?
得分 2
3条评论:
how do i get a schematic online? need it for iphone 6
完成的
Thanks Stephen. I did not move forward on repairing the phone. From what you explained I realized that it is out of my league and beyond my level of motivation. The phone is not just a toy for my kids to play with an imagine that they have their own iphone. Thanks.
完成的
添加一条评论
添加你的答案
StarrDan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
