跳转到主内容
修复你的物品
维修的权力
商店
Part of the components covered by a sticker
Inside the 13" MacBook Pro with Retina display Late 2013 there is a part close to the battery with some chips that are covered with a sticker and a warning message. I guess those are related to the battery but could not find anything specific.
After a liquid spill I have cleaned the logic board but the battery is not working and I suspect it could be because it is very sticky on that part (it was Coca Cola, terrible)
Is it safe to clean that part with alcohol as I did with the rest of the components or better not to touch it in any way?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
@claudiosposito " I just checked the battery logic board and one chip looks damaged" and "some chips that are covered with a sticker and a warning message" hard to identify. Post some good pictures of what you see with your question. For that use this guide 在已经存在的问题里加入图片 It will allow us to see what you see.
完成的
添加一条评论
1个回答
最有帮助的答案
Isopropyl alcohol is safe to use on most PCBs. Don't get it on any mechanical parts though, like optical or hard drives, or fans. Use 70-99% isopropyl alcohol and use a swab to dab it on, then if debris needs to be cleaned off, use a soft cloth. Once the debris is clear, dab on a little bit of alcohol over the surfaces in question, then let it evaporate completely.
Don't get anhydrous alcohol, as pure chemicals can be dangerous and finicky to work with.
这个答案有帮助吗?
得分 1
评论:
Thank you for the tips. I just checked the battery logic board and one chip looks damaged, I'll bring it to the Apple Store to replace the battery.
完成的
添加一条评论
添加你的答案
Claudio Sposito 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 57
