My vacuum is very, very loud
I have replaced the the brush thing and a hose that had a hole in it. But it is still very loud.
@emess117 , Eileen, There could be a few reasons for your vacuum making more noise then usual, Recheck the canister/filters for proper installation and the brush head assy. also for brush/belts installed properly. I posted a couple links below that may help you trouble shoot the noise and then replace/repair the faulty part. If still under warranty contact Dyson last link below, for parts/repair/replacement/refund. Good luck.
http://www.repairmydyson.com/strange-noi...
这个答案有帮助吗?
It sounds like the HEPA filter inside the ball - if the rubber seal is no longer fitting tightly it allows air to flow through the gap, creating the howling noise. A new seal should fix it (from ptlkmxyz).
过去 24 小时: 3
过去 7 天: 42
过去 30 天: 160
总计 37,308
2条评论
After emptying my Hoover yesterday I switched it back on and it sounded so raw and so loud ... I checked the fan belt and the brushes.... Why has it suddenly become so loud i wonder. ....h e l p !
由 Mo Rick 完成的
Mines doing the same thing but screeching noise here and there, might be just the old age.
由 Robbie Barron 完成的
