Resealing iPhone 6s after screen swap
When an Iphone 6s screen is swapped for another can you reseal the screen to the phone similar to how apple originally does it?
Hi there. I believe you meant the water resistant adheasive that have on new iPhone 6s. So here are the link for that adheasive :)
I hope that helped you out.
https://www.ebay.com/itm/191933751702
And here are installation guide:
这个答案有帮助吗?
I'm not quite sure what you mean but using the pentalobe screws and putting the clips put back in place, that should be the same as when the original phone was bought. Just have to make sure both are in place correctly and all should be well.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 763
1条评论
The adhesive that goes between the metal frame and screen is useless.
It won't help with water resistance that much or with warranty if it still has it.
I personally wouldn't bother with it.
由 Ben 完成的
