跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
old i-pod; when plugged in, screen with apple on it shows up-nothing e
Trying to start up old i-pod A1238 . Screen lights up with Apple on it, but won't go on to menu or anything else
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could try placing the iPod into recovery mode and restoring the software through iTunes, you will unfortunately loose anything on the iPod that hasn't been synced.
- Make sure your iPod is turned on and connected to your computer.
- Press and hold the menu and select buttons for between 10 and 15 seconds (The iPod starts to reboot after about 5 seconds, keep holding the buttons until it seems to turn off completely)
- The display of your iPod should now stay black, and a new USB device called "USB DFU Device" should connect to your PC.
you will then be able to restore your iPods firmware and it should work if not you are likely looking at a new hard disk.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
NJH 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 70
