Why won't my brake lights work
I have all lights working Four way flashers, tail lights, turn signals but no brake lights. I have replaced the fuse, the brake light switch, and the bulbs, still nothing what could be the problem?
Do a continuity test on the wire from the brake light switch on the brake pedal to the brake light socket in the rear of the car . There's probably a short in the wire . Hope this helps
这个答案有帮助吗?
I figured it out. It was the trailer light wiring harness. The previous owner tried rigging up a homemade wiring harness. Smh, but I just unhooked that one and did it the right way. Now all of the lightsame work. Thanks for the help
这个答案有帮助吗?
stoplights go thru the turn signal switch..even tho turn signals work contacts for brake lights may be corrodded
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 83
总计 12,426
