Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
585 个问题 查看全部
Help! Unable to boot from any disk after Sierra installation
Hi all,
So, I finally upgraded to Sierra and everything was fine the first couple of hours. I closed the lid only to realise 3 hours later that the mac never went to sleep but was instead running the fan full throttle. I had to do a hard reboot and to my horror saw that the computer stalled at the white start up screen (with the apple logo).
Additional info that might be relevant: A couple of years ago, I replaced the CD-drive with a SSD drive for applications and OS. I still have the original internal HD installed as well (but without OS of course). I have installed new 8GB RAM as well.
So far I've tried:
- Disk Utility in recovery mode (claims all disks are fine)
- Safe boot (still stuck at white screen)
- Reset NVRAM
- Reset SMC
- Single user file consistency check (fsck -fy) – showed some errors first time, but after running again it claims that everything's fine.
- Sierra reinstall three times (but of course the download itself might be corrupted)
- Booted from an external drive with a backup partition. Guess what? Stuck at white screen.
When I boot the computer in safe + verbose mode, there are a couple of errors that might interest people who know more than I do: the picture of the screen is attached below. The "master-entitled process" that was cropped off the image is named 'launchd' (1).Verbose photo
I have no idea whether this is physical damage, boot sector confusion or something else? Please help.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
Thank you for the suggestion! I did try that a couple of times early on, but to no avail.
I just now fixed it by creating a bootable disk with Terminal on another mac. I could then boot and wipe my faulty boot drive using Disk Utility and do a clean install of Sierra.
Terminal command for creating a bootable drive is (make sure the installer is in /Applications):
sudo /Applications/Install\ macOS\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/Untitled --applicationpath /Applications/Install\ macOS\ Sierra.app
这个答案有帮助吗?
按维修分数 0
添加一条评论
最有帮助的答案
The white screen would indicate to me a hard drive or hard drive/IR cable failure. Try booting to your repair partition by holding down the option key on start up and see if you can select the repair partition select it and see if you can boot and run Disk Utilities.
这个答案有帮助吗?
按维修分数 3
添加一条评论
Have you tried reinstalling OS X using Internet Recovery?
While the computer is off, hold Command+Option+R while turning it on.
It should boot into Internet recovery if you have an active connection.
这个答案有帮助吗?
按维修分数 2
添加一条评论
I finally got in after a recovery boot and reloaded Sierra, so far so good. Thanks for all the responses
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Gaspard Winckler 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 537
