跳转到主内容
修复你的物品
维修的权力
配件 & 工具
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4039 个问题 查看全部
Is it possible to swap storage of 2 iPhones
Hello people.
I have 2 iPhones
1. iPhone 5 64GB Global
2. iPhone 5S 16GB
Is it possible to remove the 64GB storage from iPhone 5 and use it in iPhone 5S which will increase my iPhone 5S storage to 64GB
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
When I will swap the storage I will straightaway put the phone into recovery mode and then restore the device. Someone in China is actually selling toshiba storage 128GB for $65. If it's possible swap the storage with a toshiba one then it must be possible just to swap the storage with an iPhone only.
He uses the storage cloner tool to clone everything present on the current storage to a new storage so when you boot the iPhone with the new storage, everything boots up as it was earlier with new upgraded storage
完成的
You can't do it yourself unless you have the hardware to actually read the NAND flash memory out of there and that would probably outweigh the price of just buying a iPhone with more storage.
Also the iPhone 5 and 5s use a completely different processor. One is x86 (5) and one is 64-bit (5s). They use different firmware like EasyIFI said. It's not as easy as just cloning the memory.
Also the encryption used on the storage has to match the phone as well (re-programming required).
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
Nope. Even if you managed to do it, the OS versions will be different (Even if both are running on the same version, its running on the version specific to that particular model).
这个答案有帮助吗?
得分 0
评论:
完成的
添加一条评论
添加你的答案
Tommy Vercaty 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 651
