跳转到主内容
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
My home and recent buttons don't work! Help!
I am happy with my device, but I have a consern. On my Samsung Galaxy Tab A 8.0, my home and menu buttons recently stopped working. I would like to know if its easy to fix, and if so how, or if its a problem with my device. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Samung Gallery 10. Home keys don't work
完成的
添加一条评论
5个答案
已选择的解决方案
Turn off the tab, then press power + vol up + home all together until it turns on. You should see some text in the corner that says "RECOVERY MODE" If the tablet goes into recovery mode, then the home button is working, its just the software. You can factory reset the tablet in settings.
这个答案有帮助吗?
得分 0
5条评论:
Didnt work but got one problem my tablet home button doesnt work i cant take a screen shot or go home screen or anything when i press my home button it doesnt do anything
完成的
if I factory reset will I lose all my pictures?
完成的
I accidentaly turned my Tab Mini 7 into the Guest mode, but then my recents button dont work, i cant see my notifies ad i cant install apps. What to do? I'm in $@$*?
完成的
I have a Galaxy Tab A model SM-T280, and within the last 2 days it has stopped showing Apps I recently viewed saying on the screen "No Recent Used Apps", yet I have accessed various apps I have, and nothing shows when I tap the box at the bottom of my screen. What is the deal here, is it some type of item was accidentally shut off and can be fixed or is it something more?
完成的
Home button and recent apps button and drop down menu not working. Took tab to experts then to Samsung was told motherboard fault.
Finally, reset to factory settings TWICE ONE AFTER THE OTHER and when rebooted EVERYTHING WORKS. Reloaded all apps and as good as new.
完成的
添加一条评论
my home button isnt working on my rsv android tablet at all and its been like this for a month now
这个答案有帮助吗?
得分 0
添加一条评论
i have the same prob in my samsung tab s the recent botton as stopped workin after i did an update version and i find out that when i on a save power mode it start working
i still didnt find a solution for the problem when i on a normal mood
这个答案有帮助吗?
得分 0
1条评论:
Question is how do u fix the prob on Android? Home and Bk buttons not wking!
完成的
添加一条评论
Why is just a few letter not working after hard rest I can't log into wifi to continue like a new tablet far as made it was hello to samsung galaxy elite an then wifi far as I got I can't type in my password to connect to wifi I wonder why this
这个答案有帮助吗?
得分 0
添加一条评论
you can install button mapper from play store and map the back, volume or power button to open recent or go back. (you can also make it so that double or long pressing the buttons does something else)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Koji101 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 59
总计 35,127
