跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touch ID fails immediately
When I try to setup fingerprint it fails immediately and it really bugging me bad
Update (01/04/2017)
this is the picture I have seen many with theirs grayed out but mine is not and reachability stills work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
to elaborate on what @eddiemmr said even if you did transfer the original home button over from your old screen sometimes the TouchID extension ribbon glued onto the metal LCD shield can be faulty casing the TouchID function not to work. First check that all the connections are correctly positioned if they are all correct and clean try taking the metal shielding from your old screen and placing it on the new one, touch ID functionality should be restored after this.
这个答案有帮助吗?
得分 2
1条评论:
Thanks I did what you said and then restored my phone and now it's back working
完成的
添加一条评论
Has it ever had a replacement screen on it?
If so did you do it yourself?
Did they/you transfer the original home button across to the new screen or was one already attached to the new screen?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
QuentaviouS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,788
