跳转到主内容
The Motorola Razr V3c is a CDMA2000 version of the Razr.
8 个问题 查看全部
#7 on key pad is very intermittent (3%)
#7 on keypad hardly ever connects. Verizon sprayed a cleaning product on the external keys. The key "clicks" but rarely makes contact. I like the phone. Repair shops quote $40 to replace the entire keypad.
Thanks for any input.
Joe
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
maybe try taking the plastic frontage off the keyboard and layering a tiny bit of tinfoil underneath it, so the contact has something to touch?
I've done this with other types of buttons before, I believe it might work for you. it's worth a shot, anyway.
hope that helps!
这个答案有帮助吗?
得分 1
2条评论:
Thank you!. Now I try then I tell you
完成的
I would use the guide to remove the keypad and would clean the contacts under the adhesive that holds the half button - i never yould use something that could shorten anything inside a phone
完成的
添加一条评论
添加你的答案
jbass43314 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 1,491
