iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
711 个问题 查看全部
iPhone 6s plus unexpected shutdown and not getting turn on
hello guys,
My phone died the other day unexpectedly, although it was charged like 60 percent.
First i tried force restarting it. but it didnt help. then i plugged it to be charged. Nothing happens as i plugged it to power. however, after like six hours it turned on by itself. next day it again died and again after some hours it just turned back on. this has happened to me like four times by now.
i have tried force restarting it. i have reset the phone using the phone when phone was on. i have recovered it using itunes when the device was working. but non of this has helped.
i should say i has not been damaged physically or has not been wetted.
When for the first time it turned off, my cars AUX jack was plugged to the device's headphone jack.
Guys i dont have access to apple stores or their repair centers. so please help me what could have caused this problem.
thank you
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 3
评论:
there has been a recent issue with iphone 6s's that make them randomy shut off. What percent does it die
Try to change ur battery..
To Robert Hayek,
Well, first time it happened when the phone was 60 percent charged. Then again it happened while it was fully charged.
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
最有帮助的答案
Morshed M , Go to the (iPhone 6s Program for Unexpected Shutdown Issues) Link below to see if you qualify in the replacement program. Good luck.
https://www.apple.com/support/iphone6s-u...
这个答案有帮助吗?
按维修分数 2
评论:
Thank you L Pfaff,
I checked the link, unfortunately I wasn't included in the program.
But it was really helpful. Thank you
添加一条评论
添加你的答案
Morshed M 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 276
