跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Question about water damaged iPhone 6
Hey guys,
So I have my first ever water damaged iPhone 6, fell in the toilet.
Some corrosion on the screen connector sockets (and corrosion on the display cables) if you know what I mean. Is that backlight water damage btw?
So my important question: I have here some "96% undenatured alcohol" (The packiging is in Dutch, but it's saying "Alcohol 96% V/V" and than "undenatured".
IS THIS FINE FOR REMOVING CORROSION?
The place I bought it from (pharmacy, because it's the only place I can buy it in the Netherlands) only had like 70% and 96% so I took the closest to 99% (that's the normal stuff I guess).
So again, will this do the job? Doesn't matter if the phone dies, it's insurance work, but I just want to know.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I'm not a chemist so I can't say if the denatured alcohol will work well or not. I recommend >90% IPA.
Obviously, clean whatever corrosion you see but remember that the water is inside the phone, on the logic board and under the shields, even under the IC's.
Open your phone and remove the logic board:
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board.
这个答案有帮助吗?
得分 2
9条评论:
Is it maybe better to buy a new logic board + screen? There is also corrosion on the screen cables itself (the point where they connect). The phone is like half a year old and I think the value of it is high enough to replace the screen and logic board.
完成的
Logic boards are very expensive and you lose whatever data you had on the original. Is this your personal phone or are you repairing this for a customer?
Try the steps I suggested and see if that helps. At the very least, you may be able to at least recover the the data. If you are a shop and don't have the tools to do a proper decontamination, then don't "learn" on a customer's phone and find a shop that can do the work professionally.
完成的
Also, if I can't fix it, "I recycle the phone on a good way" or like I keep it and use al the good stuff, you know what I mean. Is that maybe better?
完成的
The phone is from a customer and I got the phone from an insurance company, he bought a new phone when this one fell in the toilet. But it's insurance so they try if it can be fixed or not. The phone was reported in october 2016 and arrived like 5 days ago at my place. So it's a long time ago that it made contact with water.
完成的
That certainly reduces the odds of a successful recovery. Clean it up and test it out. Replace the battery and screen with some known-good parts from your inventory. If it doesn't work, test your main voltage lines to see if there is a short. You can also remove the shields if you have the right tools and test other voltage rails.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Stijn Helmonds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 339
