跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3855 个问题 查看全部
Wet phone screen/battery replacement
hi thanks a lot the only problem with replacing the screen I recently dropped my phone in the toilet causing water damaged and after this my battery dies very quickly within half an hour on 100%. so i fear replacing the screen may also cause problems and i have never changed a screen before.
Is this too risky? Thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
Rahaul k you got a whole bunch of issues going on here. You want to proceed in a somewhat logical manner. Your battery is most likely expanding due to it having failed through the water damage. So the very first thing you want to do is to not try to restart the phone sync it or otherwise continue to use it. This may further damage your phone. You must address the water damage issue first. The next thing to do is to clean it. Disassemble your phone using this guide Then clean it with +90% isopropyl alcohol. You must remove all the EMI shields. You can not properly clean it with those on. Follow this guide, and even so it was written for a 3G all the points are still pertinent to your phone. Yes, you can soak the complete board in isopropyl alcohol. While you clean your board, check for any obvious damage, like burned or missing components etc. Double check your battery connector. When it is properly cleaned, you must replace the battery. In your case you also want to repalce the complete display assembly. A glass only repair for a novice is a hard chore and almost guaranteed to fail the first couple of times. Use this guide to replace the assembly. All these steps are to avoid delayed failure caused by corrosion, which your phone is already showing. Once all this is done, reassemble your phone and reevaluate.
iPhone张图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPhone 5s 逻辑主板张图片
指南
iPhone 5s 逻辑主板更换
难度:
中等
20 minutes - 1 hour
iPhone 5s LCD及数字转换器张图片
指南
iPhone 5s LCD及数字转换器更换教程
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
按维修分数 2
添加一条评论
Definitely buy and repair the battery, if you don't it could be dangerous. You may not have to repair screen if it works fine after battery change. A screen repair is simple. Almost as easy as battery. Just be very gentle with prying up the screen that's the key part to any repair in the phone. As the screen will be the easiest thing to crack when putting back in or taking out.
这个答案有帮助吗?
按维修分数 0
添加一条评论
Just follow the iPhone 5s 电池更换 guide carefully, and heed any warnings that it gives you. It's not a particularly hard repair; just be careful to not damage the home button connector, as that component is not replaceable if damaged to retain TouchID functionality.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Rahaul k 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 63
