跳转到主内容
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
228 个问题 查看全部
Is there anyway to power on note 5 without power button?
[http://]
i damaged a part of PCB at power button area is it repairable ?
Update (01/01/2017)
some micro part
see this attachment
http://www.imageno.com/tu87c2lyldc4pic.h...
Update (01/01/2017)
those three micro parts connecting power button
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
What kind of damage? Did you damage the pads?
@saadsmh looks like somebody just put a blob of solder across those. Why not repair it properly with the right parts?
and one of that micro part was burnt too
@saadsmh which part? Take a better picture and mark the burnt out part on that. The one you linked to is not quite clear. Right now it looks like you just jumped the two switches. Use this guide 在已经存在的问题里加入图片 to add the images to your question.
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
4个回答
已选择的解决方案
That is some jacked up ish. Is that just globbed solder on the pads? Are any of the small components missing or damaged there? If I were you I would just buy some contacts and just solder them back on, all you need is a heat gun with a concentrating nozzle and some flux. I'd clean all of that solder off of there, clean it up with iso alcohol and then take a picture.
这个答案有帮助吗?
按维修分数 0
添加一条评论
最有帮助的答案
@saadsmh
  • When your phone is off, press and hold the Volume down and Home button.
  • While holding the Volume Down and Home, phone to your computer using a USB cable.
  • Continue holding the Volume Down and Home button to until your phone will boot to Download mode.
  • Once your phone boots to Download mode, press on the Volume Down button to cancel the Download mode.
  • Once the Download mode has been cancelled, your Galaxy will reboot.
  • Wait for your phone to completely start.
这个答案有帮助吗?
按维修分数 3
评论:
this doesn't works with note 5 i already tried
In that case, I suspect the power button is not the only issue.
it doesn't works on other note 5 without a power button.. only problem is www.imageno.com/tu87c2lyldc4pic.html this is damaged
添加一条评论
When you connect UART cable on Note 4 then it turns on without pressing powerbutton. Try on Note 5, it might work.
这个答案有帮助吗?
按维修分数 0
评论:
I'm newbie can you please tell me how to make a uart cable?? or tell me more about uart cable so thar I can buy one
I would just buy a pre-made UART cable from the Internet.
http://www.ebay.com/itm/like/40118376599...?
添加一条评论
I have the same problem but, i want to open up the phone to see whats wrong but i have another problem. My back glass of my Note 5 is all cracked. Would there be a problem if i remove the back glass if its all cracked?
这个答案有帮助吗?
按维修分数 0
评论:
Hi Ronerto,
There would not be any issue if you remove backglass
Kind Regards,
Karar Haider
http://www.mmstore.be
添加一条评论
添加你的答案
syed 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 17
过去的30天: 59
总计 8,403
