跳转到主内容
Model 1402 / 16 or 32 GB capacity
10 个问题 查看全部
My zune does not turn on!
I have a zune HD i had it for a while and one day it did not turn on i thought it was because it was not charged but when i go to charge it nothing happens can any one help? And can any one tell me how to do the three buttpn rest? Please? And thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
Just in case anyone else reads this, you fix this by holding down the power button for about 20 seconds.
这个答案有帮助吗?
得分 3
3条评论:
I did not know about holding the power button down for 20 seconds. I thought my Zune had died but no this got it going again. Thanks.
完成的
Thanks I had the same problem, now I use ur 20 seconds method, it worked like magic, by the 18th second it off and on again.
完成的
Tried this. Didn't work. Is battery dead. 15 yrs old
完成的
添加一条评论
I've had this problem a couple times, but as far as I can tell there's nothing you can do to really fix it. Usually if I just leave mine alone for a few days it will randomly start to work again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alpta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 29
总计 6,703
