跳转到主内容
The LG K7 is smartphone released by LG in February 2016 and runs on Android 5.1.
89 个问题 查看全部
Power port is pushed in to phone, unable to charge.
I am unable to charge my 2 month old K7 phone. Suddenly the power port became "loose" causing the cord to fall off very easily. The port appears to be pushed in to the phone a bit. Help Please! How can I charge my battery? Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Because your phone is within the one year warranty, you can get it repaired by LG for free. Contact customer service, and tell them what's wrong. Do not dismantle your device or your warranty will be void. Make sure you have your purchase info available when you contact them. Most products these days have a one year warranty. Many people forget or even don't know about warranties. I hope this solves your question. If not so, leave a comment below and I'll tell you how to fix the problem yourself.
这个答案有帮助吗?
得分 4
15条评论:
While I halfway agree with you. If the company will honor the warranty, and just give you a new phone. Pretty worth it. However, warrantys usually mean, you give them half of what the device is worth, the device, and they give you a refurbished one in return. Which is a nice way of saying used
完成的
You don't have to pay a cent for a manufacturer warranty, except for shipping sometimes. Large companies will honor their warranty and either fix or replace the phone for free, sans shipping.
完成的
Ehh... This has not been my, or many peoples experience. They don't just doll out devices, because you bought it in the past year
完成的
That's the whole point of the warranty! They fix it because they didn't make it right. Their manufacturing error, they should have to fix it. When a USB port gets shoved inside the device from regular usage, it's not user error, it's the manufacturer's faulty.
完成的
Hey hey hey. First, read my second post. Second, just because there's a warranty, doesn't mean the manufacturers will accept any phone "under warranty". Thirdly, this sounds like user error, not a warranty defect. Large companies will find any reason not to give anything away for free
完成的
显示更多的10条评论
添加一条评论
It's soldered onto the logic board. Technically it's not the most difficult. But if you don't have any experience or tools doing this, a lot harder said than done. Check out one of your local repair shops
这个答案有帮助吗?
得分 3
4条评论:
Since he purchased it only 2 months ago, he's under warranty.
完成的
Do you mean "A lot easier said than done?"
完成的
Thank you so much for your assistance, I will be checking into the warranty today. Although my past experience tells me I'll end up paying S&H (half of what I paid for the phone), IF my issue falls under the warranty conditions. Thanks again!
完成的
Yes, I'll be putting my bad a** voice on!
完成的
添加一条评论
I guess I was wrong
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
colldoll31 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 31
总计 3,639
