跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
571 个问题 查看全部
My iPad Air will not charge. The female port is damaged.
I took my iPad Air into Apple to see what was wrong with it. It was determined that the female port for charging was damaged. They offered me a refurbished iPad Air for $350. Can this be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Luckily, Ifixit sells a replacement port for your tablet for only $20. The item code is IF128-007-1. But I recommend cleaning it like Ben said first. If that fails, buy the replacement and follow ifixit's guide to replace it.
这个答案有帮助吗?
得分 5
2条评论:
Thanks to both of you!
完成的
I have this problem for ipad air 2. The female connector got pushed in and bent a bit (unlucky fall while olugged in). I don’t see repair instructions.
完成的
添加一条评论
Lightning cable not plugging in fully? Clean out the gunk using a toothpick or equivalent to unblock the charging port.
Otherwise may be a bad charger port which if I remember correctly they are soldered onto the board which is not a easy thing to replace as it will require a lot of heat and experience.
这个答案有帮助吗?
得分 2
添加一条评论
I have the same problem contacted Apple they can fix it for AU$350.00
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Missy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 34
总计 16,538
