跳转到主内容
WD My passport 500gb not detecting showing unallocated 650gb
I'm a computer hardware professional. My WD My passport 500 gb is not detecting showing unallocated 650gb I Tried all kind formatting the drive. It shows unable to format. How to troubleshoot and what component will be the problem on hardware so that I can service myself?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First, open disk management. Find your disk in that list. Once you've found it, right click and hit delete volume for each partition on the disk. Once you've done this, the entire drive will become unallocated. Right click on the volume, and select new simple volume. Once this is done, it will ask you format it. Format it to NTFS. I hope I was of assistance to you.
这个答案有帮助吗?
得分 3
9条评论:
I did that and didn't work. When I create the partition it creates only 80gb in diskmanager and others unallocated unable to create or format the unallocated partition. And I used wd formating software, acronis disk director and partition magic tools software too it didn't work saying cannot format cycle redundary error
完成的
Do not create any partitions. Make all partitions unallocated, the create new simple volume from that single partition. You cannot format unallocated partitions.
完成的
完成的
Why did you repeat it? I read it the first time.
完成的
Did it work?
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Anzar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,429
