跳转到主内容
修复你的物品
维修的权力
配件 & 工具
MacBook, MacBook Pro, 和 MacBook Air 交流电 电源适配器。
81 个问题 查看全部
Repair Magsafe 2 Charger?
Hi all,
I searched around for this, but most charging-related questions lead to troubleshooting the DC-IN, battery, etc and I couldn't find this issue specifically.
I'm an Apple Tech who doesn't have a background in electrical engineering - and made the mistake of daisy chaining a couple surge protectors together. They were like this for a number of months. This caused a few of my Magsafe chargers to go out. I'm curious whether the chargers can be repaired.
The symptoms:
  • The charger does not light up when connected to a machine (regardless of the machine).
  • The system battery icon shows that it's charging, but the status is "Battery is not charging." If I leave the cable connected overnight, the machine will usually charge up.
  • Hence, it seems the charger is providing power, but at a much reduced rate from what it should.
Is there a way to restore it to its former functionality?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
Leave the chargers disconnected from the plugs for a couple of days, then try it. Sometimes magsafe chargers can disable themselves to stop overcharging a device.
Beyond this, I wouldn't bother repairing these. You have to break the casing in half, so it never looks great when you glue it back in place. The only reason I would consider repairing these is if the cable is frayed (but then again, I probably wouldn't bother), there are no schematics for the PCB inside the charging block so it can't be properly diagnosed. You can only repair this on a basis of "component looks bad, replace it".
If the 1st solution doesn't work, I would recommend just buying another from Apple.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Colin 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 11
过去的30天: 65
总计 2,371
