跳转到主内容
修复你的物品
维修的权力
配件 & 工具
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5033 个问题 查看全部
Backlight circuit failing iPhone 6
Hi, have an iPhone 6 that had a dark patch on the top right hand side of the display. The phone worked ok. I checked the board and found that FL2024 was damaged. Looked like screwdriver damage. I went ahead and changed it but when I turned the phone back on L1503 blew. There was a puff of smoke and the top of it was expanded. I changed L1503 but the replacement also blew. Is there anything in particular that would be causing this?
Thank you
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
基本电子产品工具包
小工具包。却有无限可能。
Shop Toolkits
基本
电子产品
工具包
Shop Toolkits
1个回答
已选择的解决方案
When the magic smoke escapes, you always have to ask yourself what caused it; a defective or physically damaged component, improperly spec'd or being driven by excess current?
Clearly your backlight circuit is being shorted by something downstream. It could be the backlight itself or one of the bypass capacitors on the line. Check the PP_LCM_BL_ANODE line to see if it is shorted to ground. Remove the blown components first. If that line is shorted, then look at the caps like C1505/C1530/C1531/C2017. If that looks good, then check the cathode side of things as well.
If there is no short, then try to plug in your logic board without the screen to see if the failure is consistent with the backlight itself or on the logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
trevor 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 449
