跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
264 个问题 查看全部
Mac Shuts down unexpectedly
Problem
My MacBook Pro works fine with a fresh installation of OSX.
When I install adobe products, it shuts down unexpectedly, even if the app is not open.
It crashes also with qbittorrent, and "console" from Mac utilities.
Cause
I've had to replace my Magsafe because it died (short circuits), maybe that there is a link.
Tried
I have tried to fully reset the system, the SMC, PRAM,...
Genius Bar
I brought my Mac to the Genius Bar, they did not find any problem. They said they did not encounter the problem (are they magician?) because the problem appeared 5 sec after they gave me back the macbook
Thank you for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
评论:
My Macbook runs without sudden Shutdowns when a hdmi dummy plug is plugged In. The logic board is damaged
完成的
I got the similar problem. it is fixed when I plug in a Thunderbolt-ethernet-card. Pretty strange ...
完成的
添加一条评论
2个回答
最有帮助的答案
One option to look at is which video card you're using. For example, on mine, the integrated (Intel) video has gone out, and the computer is prone to system halts. If I have it on an external monitor, works fine. I currently have a utility, gfxCardStatus, to force it to use the higher performance card.
这个答案有帮助吗?
得分 1
添加一条评论
Changing the battery did not solve the problem.
In that kind of cases, the Logic board seems faulty.
It is strange but the mac runs fine on windows...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alansaillet 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 260
