How I can change the charging port?
Hi
I have some problem with my charging port..
I want to know if their is simple way to change it with new one
Thank you
The charging port on this tablet needs to be soldered in . Its not to hard if you have access to a heat station and soldering equipment. This video can help.
https://www.youtube.com/watch?v=4mcXJVbK...
There is also a teardown guild here
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
Hope this helps
这个答案有帮助吗?
So there is no way instead of using soldering equipment??
only if you replace the entire board
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 98
2条评论
@dr_shoaa , more info. there are probably 20 models, what is yours? Help ifixit help you!
由 L Pfaff 完成的
@lpfaff1 SM-T231 ( Galaxy Tab 4)
由 Shoaa Altalhi 完成的
