跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
U2 replaced , battery drain cured but now no charge .
Hi , i changed the u2 on my 5 s which solved the battery drain but now its not charging .
It was charging before i changed the u2 .
Did i do something wrong ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
check Q2 5v charging voltage. (U2) the TriStar is not a charging IC it switches power between ppvcc main and ppvcc batt
这个答案有帮助吗?
得分 3
3条评论:
100% your issue
完成的
Thank you , i scraped the under fill off the Q2 chip and it seemed to be cracked in half ! , replaced it and all working again ..
完成的
Your welcome
完成的
添加一条评论
If your phone is not charging, then U2 is probably not installed correctly. Perhaps some of the balls are shorted along the E75 lines which communicate with the Lightning cable.
这个答案有帮助吗?
得分 1
2条评论:
Hi , I will try again with another chip .
完成的
Hi , I have put another chip on but still have the same symptoms , and no i tunes connection .
完成的
添加一条评论
添加你的答案
markparnell1972 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 199
