跳转到主内容
与AirPort Extreme基站一起发布,这款配备硬盘的Time Capsule NAS上提供802.11ac速度。
56 个问题 查看全部
I need to change fan, how do I remove the old one?
Hey guys
I read all your great responses and guides, I thought it was the hard drive in my A1470 2tb Time Capsule that was making an awful noise but I removed it but it seems it was a faulty fan. I ordered a new one from Aliexpress but I tried to remove the "mother board" that has the fan fitted on it, but its quite stuck and my question is:
How do I remove the mother board and the fan, are there any screws or cables I should worry about or should i just pry it out?
Best wishes from Linus in Sweden
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
IFIXIT pulled a fast one on you ;-}
The guides and teardown under the Time Capsule heading are abbreviated versions as its twin AirPort Extreme has the complete teardown.
There is not true guide to take the fan out as its quite straightforward. But, you need to review this guide to get the deeper breakdown: AirPort Extreme A1521 Teardown.
这个答案有帮助吗?
得分 3
2条评论:
Thank you @danj ! Why did'nt I think of this :) Hopefully it will do the trick to change the fan and have it not sounding like a saw mill!
完成的
Whew! This looks fun! I'm starting now, will report back.
完成的
添加一条评论
添加你的答案
hoeglind 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 3,828
