Why is my tablet really slow
my tablet is really slow. takes forever to load a page. I've checked my router with another tablet and it works fine.
@kimden5 , Dennis, Use the informative links below, to get tips and tricks info. on speeding up your device. Good luck.
https://www.youtube.com/watch?v=B22FuJGR...
http://www.tomsguide.com/forum/id-205005...
这个答案有帮助吗?
Nothing has changed. Tab is just slow. I didn’t read the gripe correctly. The unit charges just fine its just that response to input is slow (loading pages, apps, etc. Plays video just fine. Streaming video information like Ventusky weather is clunky and jittery and loads very slowly. (like the days of dial up) Galaxy tab A 8
这个答案有帮助吗?
I noticed one I found at my girlfriends house slowed right down after updating to the latest OS, before the update it seemed quite quick, but obviously had compatibility issues.
这个答案有帮助吗?
My Samsung tablet is slowl downloading. Just had fibre installed still the same. Speed check with tablet 25mbps download. Speed check with Huawei phone 100mbps all good. I suspect that the tablet is using the 2.5 Ghz frequency on the router to download and the phone is using the 5 KHz frequency on the router. I cannot find out how to check my tablet to check this. I am not a techi but do have some understanding.
这个答案有帮助吗?
Just to add, and this isn't an answer to your question, my galaxy a 10 is the same, massively disappointed with this tablet, had a cheap £60 tablet before which was far better, never get a Samsung again.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 50
总计 53,821
2条评论
Please help?
My tablet is taking to long to charge, it's been 3 days now and it hasn't even got to half yet.
由 Debbie Mcthomas 完成的
Press and hold the Power/Lock key, tap Power off, and then tap OK to turn off the tablet.
Press and hold the Power/Lock key and Up Volume key at the same time.
Release the Power/lock key when the Samsung logo appears.
Release the Up Volume keys when the Android image appears.
When the menu appears, press the Down Volume key to select Wipe cache partition.
Press the Power/Lock key.
Once the message, “Cache wipe complete” appears on the screen below the menu, press the Power/Lock key to select Reboot system now.
由 Harley Middleton 完成的
