跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Touch ID ORIGINAL home button not working after screen replacement
Lately I have had problems with the touch ID not working after I did a screen replacement. The home buttons are original.
What is causing the problem? I think it's ios 10 related since I've only had the problem with ios 10 devices, but I am not sure how to avoid it.
Updaten (19-12-16)
OP here. I re-use the original flex cable that is found on the metal shield.. I don't think the problem is the cable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
12个答案
已选择的解决方案
During the time I posted this and now I finally have some answers. First, during the posting period phones suffered a so called error 53 which basically was an error that when you removed the home button flex from the phone, the phone would stop working. Apple apologized for this and removed this 'feature', but phones in ios 10 and late ios 9 really had a problem when you removed them from the motherboard.
I later also discovered that iPhone 6 touch ID flex cables are very fragile and tend to make a very small crack in the location where it twists. So if you are not careful enough or you bend it around a few times it will get damaged! Look very careful if yours doesn't have a small crack in the corner. It's hard to notice sometimes. The home button will still work but the Touch ID will get disabled because of this and there will be no solution for it. I am very careful now when removing the touch ID on this location. I sometimes remove the metal back plate with the home button still attached to the flex cable. This seems to work out for me.
I hope you have learned something because of this!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Personally the biggest issue is how you reconnected the home button flex cable at the top by the group of flex cables. I've had SO many issues with the ID not working after installing a 3rd party screen, yet always worked the first time when installing the OEM screen. The quality of these flex cables that come with the screen just aren't good enough in my opinion. Not even close to good quality sadly. All you can do is keep disconnecting and reconnecting the flex until it works and do it with the battery disconnected each time. I ended up buying a used OEM screen off ebay and it cost me less than iFixit AND everything worked perfectly the first time of install.
这个答案有帮助吗?
得分 1
2条评论:
I have a genuine screen, and have swapped out the home button to have the original (one paired with the logic board) present, but still I can't use touch ID? The connections seem firm, but no joy!
完成的
This comment inspired me to try something. It seems that the order of connecting cables vs. the battery matters. Make sure to connect the group of cables in the upper right corner before reconnecting the battery. So far this has resulted in consistent success for me.
完成的
添加一条评论
sometimes a faulty touch id extension ribbon can cause this, check to see that all the pins are correctly seated, clean and connected properly first, is this is ok and the problem still persists then the likely fix will be to swap the metal plate on the back of the LCD which has the Touch ID ribbon cable attached to it; with the one from your original screen.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
As Rayeasom has said, check everything is seated correctly, if so then you have probably damaged the home button cable. If problem persists after checking cables & connector fit a new home button, if that fails fit a new extension cable. If you do fit a new home button you will loose the fingerprint function. As a temporary fix use assistive touch in settings which will give you a on the screen home button.
这个答案有帮助吗?
得分 0
1条评论:
Sadly, this is not a one time case. Other threads have been made about this problem yet no solution is given yet.
Touch ID not working after screen replacement..
完成的
添加一条评论
Hello friends i have problem My iPhone 6 after lcd replica. If I close my phone to black screen and want to use after 10 seconds press home button doesn't want to light up the screen if I press the power button and the home button so work again home button doesn't work until I did not pressure the power button my touch id is not work home button is original please if you know what ?
这个答案有帮助吗?
得分 0
4条评论:
Are you experienced in smartphone or is this your first time?
完成的
No friends please help i dond no the problem of iPhone sencerely
完成的
hi angelina, do you solved your problem? its happening to me too...
完成的
This happened to me with my iPhone 6, you just need to get a screen backplate which only costs £3!
完成的
添加一条评论
No friends is no My first time the first time have problem i can not found My problem ?
这个答案有帮助吗?
得分 0
添加一条评论
Please help friends i dond bo the problem of My Phone
这个答案有帮助吗?
得分 0
添加一条评论
angelinaelvina ,
Set up of id fail and must you try again or is the selection gryed out to set up touch id? if it is greyed out then your home button is faulty otherwise you can place a new flex cable that runs under the metal shield.
这个答案有帮助吗?
得分 0
添加一条评论
Would turning sensitive touch off first before replacing screen help ? Since it won't be active ?
这个答案有帮助吗?
得分 0
1条评论:
OP here. I've discovered that iPhone 6 home buttons rip very easily. I now usually just remove the home button very carefully, when I can I remove it equally with the back plate cover so I don't twist the cable. If you remove the home button flex a few times it will snap!
完成的
添加一条评论
So I have an iphone 6 plus, original home button but after replacing my screen I ripped the ribbon that came with the metal shield behind the LCD, the homebutton ribbon is perfectly fine, I cant use the homebutton because its not connected to the phone itself because I dont have the connection from the metal shield, would i be able to buy a shield online and use touch ID?
这个答案有帮助吗?
得分 0
添加一条评论
My 6s home button and Touch ID works well , till I remove the screen and try it on another 6s, now I put it back and the home button and Touch ID does not work , can some one tell me what happen?
这个答案有帮助吗?
得分 0
1条评论:
update on ios 11.3.1, and it will work
完成的
添加一条评论
Best way is to swap the back plate and the button.
It worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 59
总计 64,038
