跳转到主内容
My phone says its on airplane mood but it isnt?
my phone is active but wont let me send messages or make calls it says my airplane mode is on but everytime i check it is not on? help me fix it. cant afford a new phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
6条评论:
i need help fixing my phone.
完成的
How do you reboot the phone and I don’t know how to take the battery out.
完成的
My phone is stuck on flight mode and won't let me make phone calls or send text messages even though I reset it switched on and off it still won't let me use it
完成的
Can't use phone in airplane mode it isn't can't afford a new phone only 6 months old
完成的
My ZTE ph is telling me can't make calls because airplane mode is on but it's not has no icon light up saying its on
完成的
显示更多的1条评论
添加一条评论
2个答案
First of all, check your settings then Wireless and Network. It might have a Wi-Fi calling mode turned on, which might cause some problems.
Then try to reboot the phone which helps removing glitches and bugs.
Though this is sometimes tricky depending on your phone, but try taking out your battery for about a minute and put it back in. Make sure the phone is shut down during the process.
这个答案有帮助吗?
得分 0
2条评论:
How do I fix my phone?
完成的
This happened to my moto G9. After trying a lot of online suggestions still not fixed. I retraced my activity beforehand the phone crashed. Google maps had led me into a cul de sac. Not relevant. I went to settings opened apps then google maps. Cleared cache data and problem solved. Not sure if I rebooted phone. Phones grand now.
完成的
添加一条评论
press power select restart hold vol down till boot menu comes up select bp toolsto restart i have to do this every restart but works for me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
destinygilbert42 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 153
总计 22,033
