跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Touch only working on second try
A customer brought me an iPhone 5, the problem is that always when the screen is off for a longer time (at least 10 minutes) and I turn it on again, the touchscreen isn't working right. When I turn the screen off and on again it works fine. What could be the problem? Already tried reconnecting the flex cables. Could the display be faulty?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You could have a bad screen assembly. The logical first step is to replace it with a good quality part.
The iPhone 6 and 6+ are well known to have problems with Touch (Touch Disease) but this is not a common problem with the 5.
iPhone 5 Screen图片
产品
iPhone 5 Screen
$34.99
这个答案有帮助吗?
得分 4
2条评论:
Yep you nailed it.
完成的
I noticed an increase in temperamental behaviours with touch on a couple iPhone5 after updating to ios 10. Might be a coincidence, but...
完成的
添加一条评论
there is a prossesor that starts to loose its conections due to the phone being subjected to bending.this prossesor is responsible for touch recognition.ifixit can show you wich one it is so you can replace it if it is economical to do so.There is no guarantee this is the issue but i would put money on it.good luck and always have fun fixing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ppalfinger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 76
