跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
My phone over heats when chargin?
Hey everoyne.
My phone (IPhone 5s) seems to overheat when charging. does anyone else have this problem (or know why it does) I think it may be a battery problem but I have not seen this problem anywhere else.
TIA
Keegan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
How long does it take to get very hot when you start charging it? Could be software on the phone doing stuff in the background while charging but if it is it should not occur again the next time you charge.
完成的
It usually takes about 2-3 mins, (of being used) and then it gets hot. I never usually get this problem, its a new thing.
完成的
添加一条评论
1个答案
已选择的解决方案
I guess that depends on your definition of overheating. Is it warm to the touch or hot or too hot to handle? As a reference point, a hot coffee will be ~60-70C. Is your phone that hot or hotter? That would not be normal.
As Ben says, it could be some background apps running. To test it, close all your apps before you charge and see.
That said, when a battery is discharged, a charging block can deliver 1A of current to the device so it will indeed be warm. Are you using an Apple charging brick (the small square one)? If you are using an iPad brick or a cheap dollar store one, you could be driving too much current. You want to avoid the cheapie ones as they can damage your charging circuit on your phone.
这个答案有帮助吗?
得分 3
3条评论:
Yeah, this is very well, I was thinking maybe a battery issue, (this still could be the case) thanks
完成的
I'd say normal warm during charge is 30°C-40°C and probably around 40°C-50°C if you are using it at the same time when charging from flat or under 50% to 90%.
完成的
Absolutely not. Using an ipad charger is perfectly fine as it’s the device that asks the charger for needed current. Apple tells this too. You can even use a Mac charger. https://support.apple.com/en-us/HT202105
完成的
添加一条评论
添加你的答案
Keegan Bourque 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 287
