跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
White screen on iMac 2011 27"
Hello everyone.
I have a big problem.
First of all, i know there are many of these threads about this problem, but i not manage to find a solution for me.
I have a iMac 27" mid 2011. Everything works fine, until i tried to install Bootcamp.
The installation went fine, and i could boot in Windows.
There was some Windows updates i will install, and Windows ask for reboot.
After that reboot, my iMac comes with only a white screen. and nothing else. And altso the chord sound.
I trid reset PRAM, and, COMMAND+S, D, Command+SHIFT+R+P and so on.
Nothing workes.
Is anyone have an idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
A white screen usually indicated a problem relating to the hard drive. Try starting up holding down the option key and see if you can get to the repair partition. If so, run Disk Utilities.
这个答案有帮助吗?
得分 3
3条评论:
I tried that. But it's not working. I worked with this for a long time, and an hour ago i decided to take out the HDD. Unfortinately one of the pins on the display ribbon broke, so i ordered a new one now. I will update later on the week, when i tried a new harddrive.
完成的
How did it go?
完成的
Sorry my late answer on this topic. As meyer said it was hard drive related. I took out the hard drive and formatted it from another computer. Then I put the hard drive back in and after that I could start my iMac again and install macOS from start
完成的
添加一条评论
How to do it with another KEYBOARD WIRELESS. I am with a customer iMac 27. How to make my keyboard work?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jonasbak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,330
