跳转到主内容
iPad Mini 4 发布于2015年9月9日,有着类似 iPad Air 2 的性能和更小巧的身材。
Power button isn't work after screen repair
Hi
Plz help me
Only sleep/wake function isn't working
And i can't find option lock unlock in Setting
ios10 ipad mini4
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Does the slide to power off screen appear when you hold the power button while the iPad is on or unlocked?
If yes then the issue is linked to the home button flex. I don't remember how the home button is set up for iPad Mini 4 but it it should have touch ID and hall effect sensor chip (that controls smart cover functionality, if it's broken the iPad thinks the cover is closed and disables the lock button press) on there which may need to be transferred from the old home button to the new one or if it's separate you should be able to transfer from old digitizer to new digitizer.
完成的
添加一条评论
5个答案
最有帮助的答案
Had the same problem before i noticed the small cable that needs to be soldered onto the new screen. It has 6 connection points, and after transferring and soldering the cable, the on/off button worked perfectly.
这个答案有帮助吗?
得分 2
添加一条评论
Sounds like there is a possibility the cable for the sleep/wake button is not connected properly. Could you please send me the model number? Thanks!
这个答案有帮助吗?
得分 0
2条评论:
model number A1550
完成的
When you put the device back together, (assuming you changed the screen) did you double, triple check the connectors? Made sure none of them were damaged in the opening process? If there is no visble damage, I would suggest a power button replacement.
完成的
添加一条评论
Hello.
Thanks for responding.
I honsetly still have the same problem even though i cover the sensor after transfering it from the old digitilizer the model of the ipad is A1550
这个答案有帮助吗?
得分 0
添加一条评论
a flex cable in the old screen beside home button in left side :)
make sure you but it in new screen :)
that.s it :)
这个答案有帮助吗?
得分 0
添加一条评论
The new screen must have sleep wake sensor, otherwise power button will not work. Check https://youtu.be/r2pwiSmUB30
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 4,755
