跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1646 个问题 查看全部
Why my refrigerator stops working and not getting ON again.
I had a refrigerator whose specifications are as belows
Make : Videocon
Capacity : 180 litres
Supply : 230V, 50 Hz Ac
date of purchase : 2 apr 2007
As soon as i start supply of my refrigerator it switches ON and after almost 4-5 minutes it switch OFF again and doesn't switch ON again. During the ON period (4-5 min) it does not have cooling effect.
Please tell me the possible causes of fault.
Thanks
Shaikh Sohail
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thermostat know is set properly.
The compressor starts running when i turned ON the power and after 4-5 minutes the compressor stops and the refrigerator also stops. And now if i unplug the supply and again connect (switch ON) then same thing happens.Compressor gets start for some time and again gets OFF.
完成的
添加一条评论
1个答案
已选择的解决方案
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, I recommend contacting a qualified appliance repair technician for further help.
If you can give a more detailed description of the problem I might be able to give you a better answer.
这个答案有帮助吗?
得分 3
1条评论:
good answer +
完成的
添加一条评论
添加你的答案
sohail 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 1,434
