跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
425 个问题 查看全部
Dashboard HAZARD LIGHT is out.
How do I replace the tiny light bulb for the HAZARD LIGHT SWITCH on the dashboard? I know how to replace the bulb for the clock on the dashboard but how do I replace the bulb in the button on the dashboard that is used to turn on the HAZARD LIGHTS?
Thanks again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
@mconley ,I believe I posted how you were to change the clock bulb. From that video, remove the hazzard button / take it apart and change the bulb. Be adventurous, You can do it. Check the vids may help. Good luck.
https://www.youtube.com/watch?v=gjSLqpHF...
https://www.youtube.com/watch?v=P3TqheRs...
https://www.youtube.com/watch?v=MyjDCdK-...
这个答案有帮助吗?
得分 1
添加一条评论
Check out this YouTube video
https://youtu.be/MyjDCdK-kjo
Update (12/13/2016)
Okay, sorry about the clock video.
I checked out this website and got a diagram for replacing the light to the hazard switch.
http://www.hondapartsnow.com/parts-list/...
It looks like there are 2 types of bulbs depending on the part you have (Part 11). You will have to take a look. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
That should work for the CLOCK but NOT the HAZARD LIGHT (the triangle shaped red light on the dash to the left of the clock.
Thanks anyway.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Conley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,396
