跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Doesn't wake up after sleep mode
Hi, iPhone 5c doesn't wake up after some time in sleep mode.
As long as it's in wake mode everything works normal. But when I press the sleep/power button it won't wake up after 5-10 minutes. Within 5 minutes it will wake up... After 5 - 10 minutes it doesn't turn on until I boot it up again .
There is nothing wrong with the buttons, screen or battery. I also can't find shorts.
Any ideas? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
No water damage. software works and doesn't show Strange error in log files.
What happens inside the circuit if you press the sleep button? What power/data lines/chips shut down and have to start up once you press the power button again to wake up...
That's what I like to know..
I have the schematics.
完成的
添加一条评论
1个答案
Was it water damaged? Have you tried hard reset? This is known issue when the power flat was loosing contact, but you say it isn't hardware issue...
If software doesn't work, I would bet on motherboard problem...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gordon De Clerck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 117
