跳转到主内容
Laptop upgrade - 3rd Party Battery/Heatsink Replacement + Graphics
So, my laptop battery is once again coming to it's end-of-life, and this time Apple won't replace it for free (they did it last time as it was under Apple Care and it was Christmas - the guy was being nice). I'm wondering if there are 3rd party batteries, that aren't Apple Manufactured, that actually are larger in capacity but identical in size. I mean, batteries HAVE evolved in capacity in the last 5 years and it stands to reason that the same sized battery would now carry larger charge.
While I'm at it, are there also now more efficient heatsinks/fans I could throw in?
Final question - would anyone here be able to explain to me why exactly it isn't possible to take out my DVD drive and replace it with a laptop GPU? I'm aware that since I only have Intel Graphics, I can't well just remove it and replace it. But if it is possible to connect an external graphics card, why is it generally suggested that it's impossible to connect one internally?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The newest versions of the battery are slightly larger in Capacity (5500-5800 mAh) but that won't buy you much for run time. There are quite a few out their but you do need to be careful as some are cheap knock offs which could cause problems! Here's IFIXIT's part: MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Battery Apple P/N: 661-5557
Sorry you can't put some other heat sink into your system other than the one that was designed for. You may want to do some cleaning of dust build up within the fans and the heat sink fins to improve the air flow. The other thing here is if you are up to it, is to clean off the old thermal paste and apply a fresh coat of a good quality paste. Here's the IFIXIT guide: MacBook Pro 13" Unibody Late 2011 Heat Sink Replacement which walks you though the process of taking the system apart and a list of the materials you'll need.
Sadly, no, you can't swap out your optical drive to put in a dedicated GPU chip. The interface the optical drive uses is not able to support any GPU options here (SATA). The external connection you could connect an external case which houses a PCI GPU card is Thunderbolt2. The best thing would be to sell your system and get a model that has what you want for a GPU.
Update (12/06/2016)
You face quite a few problems here trying to fit a GPU into your system. You'll need to design your own logic board with all of the needed pieces that would fit in the same space as the optical drive which would include the following:
  • Design a heat transfer/exhaust system for the GPU as it does get hot and not interfere with the rest of the system
  • Figure out how to power everything from within the system, you'd loose run time which was one of your bug-a-boo's in wanting a bigger battery
  • Design a PCI to Thunderbolt bridge so you could interconnect it to the external Thunderbolt port.
I would estimate it would cost you around 50k US between all of the engineering, parts and manufacturing. You also will need software support if you don't use a GPU Apple has already made the needed drivers.
Are you sure its worth doing all of this??
As for the battery: Nothing larger than 5800 mAh that would fit or have the correct connections to connect to the logic board.
Remember Apple never offered a Unibody 13" system with dual graphics. I think you would be happier making the big jump to the new 2016 15" Touch Bar MacBook Pro if graphics & battery life was so important. The newer systems use less power so the battery last longer. In addition you can get external USB-C batteries like Mophie powerstation USB-C to add runtime. With enough Mophie batteries you could be in the middle of the jungle for a week or more!
这个答案有帮助吗?
得分 4
1条评论:
So, battery monitor tells me that my battery is at 79% of original capacity - 4534 mAh, so full would be 5800 mAh. So I guess the one Apple gave me is the largest out there then? Are there 3rd party batteries that could give me more? I bought my wife a 3rd party battery and it's been fine for the last 3 years. Is there something I should be looking for in terms of battery specs?
I've taken the heatsink off on a 2009 15" MBP, so I think I'll be fine to do the thermal paste, that thing was a monster!
So, I totally understand that the SATA connection is in no way fast enough for the GPU, but that's not what I meant. If I can access the Thunderbolt Port from outside, why can't I access it from the inside? I don't need the port, I never use it, so I wouldn't mind losing it if there was a practical way to make it happen. Thoughts?
Thanks for this btw!
完成的
添加一条评论
添加你的答案
Suchiththa Wickremesooriya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 491
