跳转到主内容
Won't see battery after teardown
2.16 GHz
Machine was overheating and shutting down after running for 15 minutes. I tore it down, cleaned the vents, reapplied thermal paste, replaced the optical drive. Updated from 10.6.2 to 10.6.4, installed iLife "11, Norton "11 and did all updates. Machine now runs (4 hours with no heat problem). Optical drive from G5 iMac works fine. Problem is that it won't see the battery. Battery has a 90% charge and boots on another MBP just fine. Good battery from other MBP does not show. Coconut battery does not show battery. Did I miss connecting something on the logic board?
Zapped pram to no avail
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 3
添加一条评论
iPhone 电池维修工具包
只要 $29.99
Buy Now
iPhone 电池维修工具包
只要 $29.99
Buy Now
1个答案
已选择的解决方案
Reseated battery connecter to logic board. The original seating looked good. Problem fixed.
这个答案有帮助吗?
按维修分数 4
评论:
good followthru +
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 946
