跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 个问题 查看全部
MacBook Pro Mid 2010 Shuts down and restarts randomly while plugged in
Need some assistance with my Macbook Pro 15'' Mid 2010.
The computer has a nasty habit that has developed out of the blue where it shuts down and restarts whether it is running off of power supply or battery supply.
It occurs more often when running off of just battery supply, even with the charge at full. What can I try to make this situation go away?
Here's the crash Report: Crash Report
Some of the information above regarding the .com.apple extensions were not permitted as they were pegged as spam. Provided as much as the crash report as possible.
The sequence of events that most often occurs is the computer will crash without warning. It will attempt to boot. Makes it to the login grey screen. Crashes again... and then will allow me to put in my password and restart.
Mac Specs:
  • MacBook Pro 15'' Mid 2010.
  • OS X El Capitan V. 10.11.6
  • Processor: 2.53 GHz Intel Core i5
  • Memory: 8 Gb 1067 MHz DDR3
  • Graphics: NVIDIA GeForce GT 330M 256 MB
Computer background:
  • I am the original owner
  • No drops or fluid spills.
I replaced the hard drive with a Samsung 250 GB SSD last christmas.
I also replaced the original RAM 4 GB to 8 GB
The computer recently started having problems approximately 2 months ago. I have since reformatted the computer, and the problems persist. I have downloaded Coconut battery which gives the following stats:
  • Design Capacity: 7200 mAh
  • Cycle Count: 283
  • OS X Battery Status: Good
  • Battery Temp: 35.5 C
  • Charing with 21.02 Watts
(While plugged into power adapter)
According to TG Pro:
  • Battery sensor 1 & 2: 31 & 30 C
  • Battery Sensor Max: 36 C
  • Heatpipe Outgoing Air: 36 C
  • Left Heatsink Proximity 48 C
  • Platform Controller Hub Die 59 C
  • Right Heat sink Proximity: 48 C
  • Memory Controller: 59 C
  • Palm Rest Proximity 32 C
  • DC In Proximity: 55 C
Need some help with where to start. I've never encountered this problem before, and not sure what action to take next. I've read several articles talking about overheating issues, logic board issues and other such problems, but not sure if these actually apply to my situation.
The temperature does not seem likely as the computer does not seem very warm via touch or when utilizing TG Pro or Coconut Battery.
I'm unfamiliar with the logic board issues.
Any help would be much appreciated!
Thank you for your time and help in advance!
Sorry this post was so convoluted.
The character count and spam blocker of this website was quite the nuisance when trying to post and give adequate information about the problem I'm having.
Update (12/04/2016)
So it seems like my problem may lie in the graphics card itself. I downloaded a program called gfxCardStatus 1.8.1 and am currently forcing my computer to run off of the intel card only. For the moment this seems to have solved my issues. Time will tell if this will keep it from occurring...
Is a repair on almost 7 year old computer actually worth it? To me the computer runs as fast as I need it to. I have updated with a SSD HD and installed the "max" 8 GB of RAM. The most taxing thing I do with my computer is record and edit audio in Logic Pro.
I have been looking at new computers prior to finding the program I previously discussed and the 2016 Macbook Pros do not seem that impressive. Have the 2015 MBPs seemed to be pretty reliable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
6条评论
@jthzp9 - Review the Crash Report I created using your snippets. You may want to create a fresh one.
Next time I think you'll find attaching a PDF file is a lot easier than trying to paste the elements as comments ;-}
Click on the far right icon in text box to get to the media manager.
完成的
If you can live with the reboots then you should get more years out of your MBP. Mine does the exact same thing, same crash report. However, it only does it when I put the computer to sleep and upon opening it up again it would crash and reboot. After that I am able to work all day long without crashes.
完成的
I have solvede same problem with https://www.youtube.com/results?search_q...
完成的
Can you please link to the exact video that solves the problem from that youtube channel? Thank you.
完成的
显示更多的1条评论
添加一条评论
10个答案
已选择的解决方案
Guys,
What I have done is more of a bandage than a true fix of the issue but after researching the subject, this was the best solution to keep my computer running for as long as possible without doing any major surgery to the motherboard and graphics card.
Download gFx CardStatus v 1.8.1, I know there is a newer version out there, but this one seems to work best for me. Every time I start my computer I make sure that the app is enabled and force my computer into Intel Only mode. I have issues when it is in the dynamic switching or Nvidia modes.
I am able to still perform all of the functions that I originally used the computer for, granted I never used it for video/photo editing.
Again, this is not a permanent fix. However, it does help get a bit more longevity out of the computer.
This is actually a very disappointing defect from Apple and hope in the future they consider higher quality components and improved structural design.
这个答案有帮助吗?
得分 6
5条评论:
How did you get yours to turn back on though? I can’t get mine to turn back on!
完成的
you are da bomb!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! this werked
完成的
Oh my.. this saved my machine thank you!! **I actually downloaded it and stupidly updated it to the latest version-big mistake. The version that works as you mentioned is this one 1.8.1. Best!
完成的
I have the same issue and indeed the fix with the gFX does work but not always. I does toggle sometimes. I have fixed the issue as follows , and that fully prevents the issue with video card and no longer reboots or crashes. Here is how:
1.) Install the gFX Card Status app
2.) Set it to Integrated only
3.) Open keynote and create a slide, insert a picture into the slide
4.) Leave keynote open at all times.
Your mac will no longer reboot as keynote forces the mode to be fixed for the video cards..
完成的
Does anyone know where to find gFx CardStatus v 1.8.1 from a TRUSTWORTHY download site? I went to the programmers page and it appears to be only the latest versions available, whereas folks in here are saying it needs to be v 1.8.1. Saw v 1.8.1 on a couple of sites but when you go to download them it isn't clear which version you are actually getting and I don't know which sites are even trustworthy. Wish I could get it from the original programmer.
完成的
添加一条评论
最有帮助的答案
Hey Jared, this is sadly a common problem with A1286 15" MacBook Pros from 2010 - I have an exact same MacBook Pro with the exact same problem :(
Anyway, the issue is most likely caused by a faulty capacitor on the motherboard. There is a voltage rail that supplies the frame-buffer, which acts as a short-term memory bank for the graphics processor. One of the decoupling capacitors on this voltage rail is a poly-tanalum capacitor, which isn't very reliable when subjected to many heat cycles. This results in the frame buffer voltage rail dropping in voltage every once in a while. If the GPU's voltage drops along this voltage rail, it stops working, resulting in the kernel panic, and sudden restart.
You can either get a new motherboard and install it, or you can get the board repair and pay less. This isn't an easily diagnosable issue though, due to it's intermittency and the fact that most people think the "GPU" is at fault. One thing to note though, is that "reflowing" the graphics chip with heat (which is a "repair" that many places do) will temporarily keep the issue from happening, but is not a proper fix as the issue will conveniently come back again after your warrantee expires. If you do go the board repair route, make sure that they know what they're doing.
If you're feeling ambitious and are comfortable with rework and soldering equipment, you can replace this capacitor and see if the problem goes away.
这个答案有帮助吗?
得分 17
12条评论:
@jthzp9 This is likely the cause. The capacitor in question is C9560, which fails due to the same reason as C7771 (on 2008 models). Replace this and it should resolve your issue
完成的
Hi Jared, I have the same problem - but it occurs mostly while working in Logic... does this happen to you as well? The crash/restart happens when the discrete graphics processor gets a lot of work, a likely moment for overheating it seems. Under 10.6.8 it did not happen often and/or was kept on control by gfxCardStatus, but under Mavericks it happens now about every hour. It seems that Logic forces the use of the discrete NVIDIA GeForce GT 330M graphics card. My MacBook 6,2 runs beautifully, otherwise.
Anyway, thanks so much to Sam Freeman and Reece for pointing to a solution, finally!! I hope to hear about a successful repair...
完成的
I have never actually performed this repair..until last night! I had a 2010 15" 2.4GHz lying around that had the kernel panicking issue, and would die within 5 minutes when running Furmark, an app the stresses the GPU. I replaced the capacitor C9560 with another 330µF capacitor from a donor board that was not a tantalum capacitor, and so far, the computer has been running smoothly. It has been running Furmark for over 5 hours with no issues!
完成的
Nice one Sam :) Just did another one of these a couple of days ago, where the customer was told it was a GPU issue. Unfortunately it is a very common issue...
完成的
This is a known problem from Apple. I made a program to fix this issue. You can check it out here, it's free and open-source : https://github.com/julian-poidevin/MBPMi...
完成的
显示更多的7条评论
添加一条评论
hello to all.
I just bought a 2010 MacBook Pro 15' at a pawnshop and said no password.
I was able to get APPLE customer care to unlock and download Sierra.
Just a couple of days ago it has been shutting of then starting up with no warning.
did your work on your own MACs work???
Update (06/14/2017)
please send me a picture of the C9560 and one of the 330uF to identify what needs to be removed and what needs to be installed.
What I looked up doesn't look like anything on the laptop circuit board/s.
thanks!
这个答案有帮助吗?
得分 2
2条评论:
My MacBook Pro 15" had the same problem, and would constantly shut down intermittently. I found a local computer repair centre and replaced the capacitor C9560 which needs to be replaced with another 330uF capacitor.
I have not any problems since and it only cost me $ 46.00.
完成的
There is a fix by MBPMid2010_GPUFix-master. Compile with Qt and run.
Problem fixed! :-)
完成的
添加一条评论
I have a 17" MBP mid 2010 with the same problem. Do these fixes work for 17" model?
这个答案有帮助吗?
得分 0
添加一条评论
I also have the same problem. I can’t even install OS X, in the process it’s restarting continuously.
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
I have Macbook Pro 15” mid 2010 version 6,2
i7 - 8GB RAM - 250 GB SSD
OSX High Sierra 10.13.6
My solution to the problem:
Good ventilation Cooling Pad
like those ones: https://www.amazon.com/Laptop-Cooling-Pa...
Download an older version of gfxCardStatus which has the opetion to stay on intel only Graphics chip
http://gfx.io/downloads/gfxCardStatus-2....
Enjoy
这个答案有帮助吗?
得分 0
添加一条评论
I have solved with Luis guide
这个答案有帮助吗?
得分 0
1条评论:
Wich one? The link you sent has many videos.
完成的
添加一条评论
my MacBook Pro 2010 keeps restarting please can you help me with this problem .
这个答案有帮助吗?
得分 0
添加一条评论
I had the same exact problem with rebooting. It appears that Apple used a week capacitor on the motherboard that causes the rebooting. I sent my MAC to The Rossman Repair Group in NYC and they replaced the capacitor. My MAC has not rebooted since the repair. The cost was $200.
这个答案有帮助吗?
得分 0
添加一条评论
Anonymous UUID:       2B023E99-AED4-FB14-A79E-F2AC21AF8250
Wed Feb 21 15:39:46 2024
  • Panic Report ***
panic(cpu 3 caller 0xffffff7f9856a8d3): "GPU Panic: mux-regs 2 3 7f 0 0 0 severity 3 WS-ready 1 switch-state 0 IG FBs 1 EG FBs 0:3 power-state 0 3D idle HDA idle system-state 1 power-level 20:20 connect-change 0 : NVRM[0/1:0:0]: Read Error 0x00000100: CFG 0xffffffff 0xffffffff 0xffffffff, BAR0 0xd2000000 0xffffff913573d000 0x0a5480a2, D0, P3/4\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleGraphicsControl/AppleGraphicsControl-3.20.18/src/AppleMuxControl/kext/GPUPanic.cpp:170
Backtrace (CPU 3), Frame : Return Address
0xffffff802326a8a0 : 0xffffff801726ae76
0xffffff802326a8f0 : 0xffffff8017394484
0xffffff802326a930 : 0xffffff8017386654
0xffffff802326a9a0 : 0xffffff801721ce60
0xffffff802326a9c0 : 0xffffff801726a8ec
0xffffff802326aaf0 : 0xffffff801726a6ac
0xffffff802326ab50 : 0xffffff7f9856a8d3
0xffffff802326abb0 : 0xffffff7f990ad441
0xffffff802326ac70 : 0xffffff7f991791ca
0xffffff802326acb0 : 0xffffff7f99179235
0xffffff802326ad30 : 0xffffff7f9a2017f0
0xffffff802326ae50 : 0xffffff7f9919ad35
0xffffff802326ae70 : 0xffffff7f990b4048
0xffffff802326af20 : 0xffffff7f990b1a84
0xffffff802326b110 : 0xffffff7f990b3d2a
0xffffff802326b200 : 0xffffff7f9933121e
0xffffff802326b270 : 0xffffff7f993314f3
0xffffff802326b290 : 0xffffff7f9932e9c4
0xffffff802326b4c0 : 0xffffff7f993282ca
0xffffff802326b630 : 0xffffff7f99329e74
0xffffff802326b680 : 0xffffff7f99329556
0xffffff802326b700 : 0xffffff7f9932976a
0xffffff802326b790 : 0xffffff7f993124bb
0xffffff802326b800 : 0xffffff7f99312db1
0xffffff802326b850 : 0xffffff7f99313157
0xffffff802326b8b0 : 0xffffff7f993138ea
0xffffff802326b8f0 : 0xffffff7f992e2e03
0xffffff802326ba70 : 0xffffff7f992e17cb
0xffffff802326bad0 : 0xffffff80178c2878
0xffffff802326bb20 : 0xffffff80178c0be6
0xffffff802326bb70 : 0xffffff80178c9667
0xffffff802326bcb0 : 0xffffff80173417e4
0xffffff802326bdc0 : 0xffffff8017270380
0xffffff802326be10 : 0xffffff801724d6ed
0xffffff802326be60 : 0xffffff80172601fb
0xffffff802326bef0 : 0xffffff801737033d
0xffffff802326bfa0 : 0xffffff801721d666
      Kernel Extensions in backtrace:
         com.apple.driver.AppleMuxControl(3.20.18)[F7F686D3-0917-3DF0-B1BE-A002B920B866]@0xffffff7f9855c000->0xffffff7f9856efff
            dependency: com.apple.driver.AppleGraphicsControl(3.20.18)[EA19739D-41D6-374F-AEC4-80CFB300B7D6]@0xffffff7f9851d000
            dependency: com.apple.iokit.IOACPIFamily(1.4)[95DA39BB-7C39-3742-A2E5-86C555E21D67]@0xffffff7f97c6f000
            dependency: com.apple.iokit.IOPCIFamily(2.9)[F763C275-306F-358F-B6B0-0FD93486BD5F]@0xffffff7f97a94000
            dependency: com.apple.iokit.IOGraphicsFamily(519.23)[81D774E8-DD11-3866-B90A-E855215EDB60]@0xffffff7f981fc000
            dependency: com.apple.AppleGraphicsDeviceControl(3.20.18)[39C0D061-25CF-3D9B-815F-D99FF4E1455B]@0xffffff7f9850d000
         com.apple.nvidia.classic.NVDAResmanTesla(10.0.4)[F8258F0F-61AD-30F4-BDD5-B18CCAAE535A]@0xffffff7f9905c000->0xffffff7f992c4fff
            dependency: com.apple.iokit.IONDRVSupport(519.21)[B9EB0174-55E4-3CB1-9802-E74BB1BD5EF0]@0xffffff7f98534000
         com.apple.nvidia.classic.NVDANV50HalTesla(10.0.4)[5DCF031B-F81F-32A3-ADCD-18E16EAC7CF0]@0xffffff7f9a0dd000->0xffffff7f9a385fff
            dependency: com.apple.nvidia.classic.NVDAResmanTesla(10.0.4)[F8258F0F-61AD-30F4-BDD5-B18CCAAE535A]@0xffffff7f9905c000
         com.apple.GeForceTesla(10.0.4)[F2D8123F-1EF8-3F6C-8C62-B2CD37544578]@0xffffff7f992d0000->0xffffff7f9938efff
BSD process name corresponding to current thread: Google Chrome He
Mac OS version:
17G14042
Kernel version:
Darwin Kernel Version 17.7.0: Fri Oct 30 13:34:27 PDT 2020; root:xnu-4570.71.82.8~1/RELEASE_X86_64
Kernel UUID: 5E83A13A-32F5-3604-8591-50E2F2F70DC6
Kernel slide:     0x0000000017000000
Kernel text base: 0xffffff8017200000
__HIB  text base: 0xffffff8017100000
System model name: MacBookPro6,2 (Mac-F22586C8)
System uptime in nanoseconds: 18490472856255
last loaded kext
这个答案有帮助吗?
得分 0
1条评论:
Can Anyone help me on this issue?
Thank You Very Much
Marino Galli
完成的
添加一条评论
添加你的答案
Jared 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 74
总计 66,527
