跳转到主内容
Guides and support for various television (TV) brands and styles.
9023 个问题 查看全部
Would you recommend to look after this TV defect myself?
My Tv is a Sony 48KDL600b model. My little niece fell on her knees on it, now there's a tiny bruise on the upper left of the screen. There is color in that region still. If I look from below I can see that some panel underneath the screen looks wavy in the bruise region. There's a hole that indicates that something fliped out. So, my question is, should I teardown the TV and just try to reacommodate whatever fliped out. I just don't want to waste my TV totaly, but it looks like a relatively easy fix can be made. Believe me, it looks way worse in these photos than in IRL. Thanks for your time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@santimaci seems like there are a couple of numbers missing on your model :-) should be a 40, 48 or 60 in front of that. Anyhow, from what you are describing it sounds like either pressure marks or a broken LCD panel. At this time I suggest you leave it alone. Post some images of what you see with your question. That will allow us to see what you see and hopefully help you a bit more. Use this guide for that.
这个答案有帮助吗?
得分 3
4条评论:
Done. Photos and more details.
完成的
Looks like a diffuser sheet that got pushed in. It is not just about taking the TV apart but you would have to also take the panel apart. Not a big job, but a very tedious job. I'd leave it alone until you get to the point where you really can't stand it anymore. LCD itself looks fine so it should give you no further trouble. BTW hope your little niece is fine and that nobody got really hurt.
完成的
She's okay. The incident happened like one year and a half, LOL. Better not screwing around with this, so. Thanks.
完成的
@santimaci that was funny:-) In that case I'd definitely leave it alone. If it hasn't caused any issues yet, I bet it wont in the future.
完成的
添加一条评论
添加你的答案
Luis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 157
