跳转到主内容
修复你的物品
维修的权力
商店
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5139 个问题 查看全部
Broken screw for front panel
While repairing a broken front panel of a iphone 6 I removed the 1.6 mm screws on the right side of the panel in step 35. One oft the screw heads broke. But I could get it out. Can I reassemble the phone without getting a new one or is it not recommended. If I would need the screw where could I get it.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Do you mean this step?
iPhone 6 LCD屏幕面板的更换
Those upright clips (between the screws) on the shield plate are what "lock in" when you secure the screen assembly in the housing. They are not critical for the phone to operate, they are there to structurally support the clips when you remove the screen assembly. Screw kits can be bought if you want to replace it. I always keep some on hand but for a fixer, I would probably just use a screw from the left side (the middle one) and use it on the right as it is longer distances between screws and it will need more support.
这个答案有帮助吗?
得分 2
评论:
Yeah that is what I did on the short side I just used two screws and now I put it together and it works great. Thanks for the answer.
完成的
添加一条评论
添加你的答案
Claes 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 55
