跳转到主内容
A 7" tablet with a Android 4.2 (Jelly Bean) operating system.
31 个问题 查看全部
How do I unlock my tablet, can't remember the pin I used
i can't unlock my tablet or reset it. it won't let me leave the lock screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
5个答案
最有帮助的答案
On the RCA tablets if you cant remember your password and have to do a hard reset on it you power it off first then when you go to turn it back on hold the power button and volume up button at the same time. When the picture of the dogs come on the screen hold the power and volume up button for 2 seconds and release. After the screen loads you should get the android on the screen and it should say no command at this point hold the volume up button for 5 seconds then a menu will come up allowing you to wipe and reset the tablet. Hope this helps
这个答案有帮助吗?
得分 1
1条评论:
What if it don't work
完成的
添加一条评论
I forgot my pin screen is locked. How do I get into my tablet
这个答案有帮助吗?
得分 1
添加一条评论
No Android setting lock battery disconnect after 3 hrs did nothi b g still locked rca code 0530 does nothing any help would be appreciated I'm just gonna take the 10lb sleg to it trying for days to unlock it .,
这个答案有帮助吗?
得分 0
1条评论:
I have the exact same problem
完成的
添加一条评论
J’ai oublié mon mot de passe pour débarrer ma tablette …….que faire…
RCA 8 Appollo
J’aimerais avoir une réponse en français svp
Johanne Vallée
这个答案有帮助吗?
得分 0
添加一条评论
How do I unlock my Proscan with a pattern
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joan Peterson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 15
总计 9,014
