跳转到主内容
The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
52 个问题 查看全部
Ink system Failure, I can I fix this problem
I install new cartage, but now I'm having a problem..I'm getting a message stating...ink system failure and the message is asking me to turn off printer and back on...But the message is still appearing.. How can I solve this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@rickyb154 ,Ricky as you probably know already HP recommends there cartridges as replacements only. Below is a trouble shooting link, for you to check out for ink system failure message. Good luck.
http://support.hp.com/us-en/document/c01...
这个答案有帮助吗?
得分 2
2条评论:
I tried it and still I'm getting the same error, is there anything else that I can try.
完成的
@rickyb154 , Rickey, If you tried it, Hp stated if none of the things from there trouble shooting page worked to replace the print head. You can use the link below to see if any waranty or to contact HP.
http://www.support.hp.com/us-en/checkwar...
完成的
添加一条评论
添加你的答案
Rickey Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 6,591
