跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2619 个问题 查看全部
iPod won't charge and is acting funny
For some reason, whenever I try to charge my iPod touch, the charge icon won't come up, it'll go from half to power to red in less than 30 seconds, will die, then repeat when I try to charge it again. I've tried restarting my iPod and even blew in the charging part thing, but nothing is working. My last resort is getting a new iPod because if have precious pictures on this current one. Any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If the iPod is taking forever to spring to life when on charge, then once charged the battery depleted quickly or has a rapid jump down in battery percentage this is a classic sign that your battery needs replacing. You'll find a guide on how to do this on this site and replacement batteries are readily available online.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
Try taking a small needle and cleaning out the bottom of the charge port sometimes lint from your pocket builds up in the port and gets packed in more and more until it cant fully connect and charge anymore i've had this issue twice with the new lightning plug
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
efooks619 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
