MagSafe doesn't turn amber
When I plug the MagSafe 2 on, the light turns green for a second and then it doesn't turn amber, how it is supposed to do. In addition it doesn't charge. I have checked the cable and there aren't any cuts or damages. What to do?
What's the history of the device? This can commonly happen with things such as liquid damage or use of a non-Apple branded (eBay) charger. Depending on that, this could either be an issue with the logic board or simply just a bad battery.
由 Matt M 完成的
Hi, I have the same problem.
Do you know the name of the part inside the Mac air mid 2011 to be changed once you do not have good connection?
Thank you,
由 diegoaranaparera 完成的
