跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
My phone won't turn on even if I charged it for hours
my phone did not have any battery life left so it shut down.
i went home while charging it using my portable charger for 3 hours.
when i reached home and charged it using the plug, after a few hours only the picture of the battery can be seen. i wanted to try restarting it by connecting it into itunes and pressing the home button and the power button but my home button is jammed.
is there another way to turn my phone on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
hello van, you need a new battery for turn it on!
这个答案有帮助吗?
得分 0
1条评论:
ok i will try it then :) thank you :)
完成的
添加一条评论
Change the battery and then plug in charge.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
van 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 86
