Intermittent unstable network connection
I have installed annke sannce home security cameras and the local internet connection is unstable
This is a nvr unit with Poe Ethernet cable hard wired not wireless
The modem router and all cables are working well, firmware has been update and the system was working for about 1 month
Now only works on 10 system reboot but unstable
Hi, Can you connect the NVR directly to the network with an ethernet cable (bypass the POE) and see if it is the POE section that is causing the instability?
Perhaps there is something on the AC power circuits in your property affecting your POE e.g. like a fridge starting or air conditioning unit starting etc.
由 jayeff 完成的
