跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
111 个问题 查看全部
Green light of death help
Mitsubishi tv dlp wd60c9- tv stuck on welcome screen green light blinking green fast I already replaced two 820uf capacitors still doing the same thing. The weird thing is. Is that the tv code is showing 33. Air filter cover is open. Makes no semse please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
@joshstoney it's a beast to figure out. Most common issue with that are the caps, and I wonder why you only replaced those two? Most of these sets require a whole bunch of caps to be replaced.
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
rsx needs reballing or your rsx chip is dead
The gpu is struggling and is on its way out, hairline splits in the solder balls etc.
Plus the solder balls used on the ps3 gpu is tin and sh!t quality, high quality lead solder balls last alot longer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh stone 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 86
