Computer won't turn on.
I turned the computer off and tried to turn it back on, but instead of turning on, the green power button started lighting on and of every so often. I took the battery out so it stopped flashing. When I put it back in, it was the same. I also noticed that when I click the power button, the light that says that "you are charging the computer" comes on and if i hold it, it stays on. When I actually charge it, it sometimes lights up and sometimes doesn't. Can you please help?
18条评论
Hi , I put my laptop Sony VAIO in charge and when I came to turn it on , it’s not getting on , plz help me the model number is vpcsb31fx
由 Zainab 完成的
I have a similar problem, I haven’t used my Laptop for a month or so did you ever solve on how to power it on?
由 Stephannie Espina 完成的
No, sorry I didn’t, I just ended up buying a new laptop.
由 kdcao1 完成的
I'm having the same issue maybe there is a way to get around the power button like a hacked version like u can do on desktops.
由 Daniel Loper 完成的
Hi my laptop was also from Sony viao model SVT . At first i can switch it on as usual and doing my assignment and then the battery is running out so i charged it. Then after a while i tried to switch it on and it doesnt work. Can someone help me im a student so i really need my laptop back so that i can work on my assignments
由 aliatrbl 完成的
显示更多的13条评论
